Absolutely correct on all counts.
Spring on the left is the new to me Curry 4". One on the right is allegedly a ProComp spring installed by the PO.
I suspect the rear springs caused my rear shocks to blow...Black Maxes...but again, just a theory.
Springs were on my list of things to do but down on the list until the right deal came around.
Almost done installing.
The oh boy was from a new springs being 2 in taller and I barely pried out the old ones. I cheated a little and used a spring compressor.
I'm in desperate need of new control arms. The OEM arms bind up before I hit the bump stops. Which puts me in danger of ripping off the brackets. That's next on the list. Control arms...not ripping off the brackets...
-Mac
Don't feel bad. I used spring compressors on my front currie 4" springs.
I put some new rims and tires on the Jeep today
I‘ve been busy since I bought the Jeep including replacing
Spark Plugs
rear diff fluid- looked clean
front diff fluid- looked black
transfer case fluid- looked black
replaced steering shock
replaced radiator and thermostat
installed disconnects
front sway bar bushings
installed B&M magnum grip pro shifter
new exterior door handle paddles
black vinyl wrap to cover up where it looked like a bear tried opening the door
light bars
under seat amp and sub and raised rear seat
new led tail lights
and lots of little things etc etc
brakes pads and rotors have arrived and will be next
Spark Plugs
light bars
new led tail lights
Is that a factory color?
Reactions: John Cooper
Last couple days I made a couple rod holders, and on the "new" tub I took 3 hours to extract(drill through) a broken bolt and patched a three of the 15 or so holes with sheet metal plugs glued in with automotive panel adhesive( holes from rocker guards and a roof rack)
