https://www.jeepcables.com/products/2000-2006-jeep-wrangler-4-0l-250-320amp-high-output-alternatorThat's what my alternator looks like. Nasty!
Is there a good replacement or easy upgrade?
Qtec has Crown, Omix, and Mean Green.
Noticed that the OEM breather cap for the front diff had started to crack and crumble apart. Replaced it with a Dorman breather.
Drove it to NH to cross off some more class 6 roads after rotating tires . Buddy bit off a little more than he could chew in a few spots.
Looks like it may be a little pressed down from shipping. Make sure it 'shakes' a little if you tap it so it is set to breath. If it's pressed down and the pressure rises, that cap could blow off. Should be like a top on a pressure cooker where it 'bobbles' or shakes a bit like it's loose.
Axle back under, brackets welded, brake lines run still need to bleed but flipped calipers and e brake kit attached. Links remounted sitting at 99”. Added piece to rock sliders to match wheel well lines. Still a few things to finish up like EVAP stuff and numerous little tweaks. Then send stuff off to powder coat but may enjoy driving it again for a bit. Thankful for great friends with great skill sets. Need to have buddies shop cut some gussets for shock towers still but can see the finish line.
I know right I definitely haven't seen that setup over 100 times (I'm also jealous)
But hey I wouldn't mind seeing the undersides again
ok ok! I'll get pictures tonight!
It is tonight and yet no pictures...ok ok! I'll get pictures tonight!
Yet again.....No pressureAye.....No pressure
I just prayed that it's still there when I get back. Left it in Tennessee while I'm recovering from shoulder surgery at home in Arkansas. There's a lot of jeep thieves out there.
Little sneak peak, picked up from Powder coaters. As expected Mopar solar yellow fresh powdercoat not a perfect match to 18 year old mopar solar yellow paint. Wont win any Sema awards but still looks great. got to button up genright filler bezel and gas cap, then start on front. Poison spyder front fenders will be powder coated solar yellow as well, once we get coilovers in there.
Just because we know what a Savvy trans skid looks like we would still like to see yours.
