installed my hot new kicker box in the center console :ROFLMAO:
Installed a new coolant reservoir-struggled to pull loose. Touched up a bracket to the windshield wiper reservoir with black rust resistant paint (struggled to remove paint cap and realized I’m getting old) while putting in a new motor for the windshield sprayer.
after one year what do you think about RC fender flares? i'm thinking to buy it because i don't like to paint the OEM.
They're fine. Not outstanding, but fine. The appearance is still good, and they're holding they're color, so no issues there. I like that they're a little wider than stock, pretty much the same width as the Rubicon flares. They don't seem as stout as stout as the originals. As sad as my originals looked, I'd make the purchase again.
Reactions: Kiwi TJ
Got rid of my leaky derale cooler
Snapped some pics before i took it off
I'll do a better job now that I'm not limited to a fluxcore welder on 120v 😆 and with my Savvy tummy tuck I won't do this mounting style again,it'll be upfront now! Might be using a unit from setrab!
Left some big stains on the driveway but oh well 🤷 it's off 😁
It took me longer to push the hose over the barbs I added when I cut the stock line.....
I struggled for a good 10 mins pushing it on.....safe to say it ain't coming off 🤣
Now some pressure washing will ensue since that cooler was Spraying a fine mist of fluid on the whole....damn underside of my jeep........it was so bad the backside of my jeep had mist coat of ATF
Also i needa take care of My RMS,gonna be on my 3rd felpro replacement so I'll be running a Mopar one that seems to yield great results when done right 😁
Kitty litter is great for getting crap out of driveways - get the corn based ones and then grind it into the concrete with your foot. You'll see it get brown as it soaks it up and then you can sweep it up and use more.
I got all the PS fluid stains out of my old driveway like that after my steering gear dumped all its fluids out
Thanks for the tip! I'll try that some other day since it's quite windy out today(I'm also being lazy😆)
Any tips on old oil stains? Soaking the stains with some purple power and doing some scrubbing seems to lighten them.....doesn't quite remove them
Reactions: matkal
On concrete? Kitty litter works decently on older stuff too, you really gotta sit there and grind it in though. They also sell some kind of acid-based cleaners at home Depot I believe, but I never had to use them.
Reactions: D's Jeep Wrld
Yes sir on concrete,I'll need to check out those acid based ones 🧐!
Gee wheeze to be polite. T-Case Fill plug still stuck, tried again with some kroil and half inch drive, I have two options, drop and relocate air tank or drop skid plate. On the trail check and fill would be impossible with tank where it is, sure not dropping skid on the trail. removing air tank will require driver seat removal which is an issue as well. I pretty sure I will be dropping t-case, so back to removing skid and relocate air tank. I tried a new grease gun was going smoothly until a zerk busted off, arrrgg….
View attachment 587257View attachment 587258View attachment 587259View attachment 587260View attachment 587261View attachment 587262View attachment 587263View attachment 587264View attachment 587265View attachment 587282View attachment 587283
I forgot to grease new u joint, got that done, rear driver long arm, stopped when upper zerk snapped and nicely stuck in nice new adapter. Found e-brake cable are one of the rattles, picked up some Adel clamps I will attach to u-bolt with 1/2-20 nut on top of lock nut, Per fab-tech manual they should be under c-lock-nut on u-bolt and bolt cut this op was not done. I don’t think I can repair zerk with long arm in place. My new priority is to finish an e-bike build to use when Jeep is down.
Looks like I will be down again for while.
Have not done jack squat on Jeep Yesterday or Today except ordered a different 90 grease adapter
It looks it might work in tight spaces and less likely to break zerk? Ordered zerks as well. It has been a lazy weekend so far, we should get rain starting tonight 🙏
Brake cleaner works well. I've never tried kitty litter though, maybe a combination of the two? Litter then brake cleaner.
Tinkered around modifying Adel clamps for loose e-brake cables.
IMG_7654.jpegIMG_7660.jpegIMG_7657.jpegIMG_7661.jpegIMG_7662.jpegIMG_7610.jpegIMG_7612.jpeg
Trashed smaller Adel clamp trying foolishly to enlarge bolt hole, picked them up from this local hardware store Lucky’s pronounce Lukeis one of my go to stores, one doller a clamp. Lots of aerospace surplus from Lockheed. Lot of resources here for the studio industry and me! I mocked one on u-bolt good to go after Eastwood anti rust stuff dries. Stuff makes your head spin reminds me anti fouling boat bottom paint. That’s all for today….. Time for football !
View attachment 588258View attachment 588259View attachment 588260View attachment 588261View attachment 588262View attachment 588263View attachment 588264
Learn something new every day.. Never knew those were called Adel clamps
