Block heater is on driver side back towards the firewall.
It's just a picture of a wire going to the grill not the engine lol
True but it's going to the pass side where the battery is and where most people would mount a battery tender.
Against my own better judgement, I loaded up the parts shotgun and blasted away at my "no start" issue that began 2 weeks ago. New battery from Costco and new starter from Rockauto.com have NOT solved the no start. When I turn the key to the first position, I get power to everything (lights, climate, etc). Past that to try and start, nothing. No click of solenoid, no nothing. I'm thinking bad ground at this point, but the weather has been keeping me from chasing this down:
Luckily, I have the truck as a backup. Not as fun to drive, but actually starts!![]()
Swapping out old POS parts with good parts. Have to alter my Barnes track bar bracket but nothing major.
Name a better company than RockJock, I'll wait
When you install the track bar you may want to put anti-seize on the frame side bolt shank where it goes thought the Johnny Joint. Found mine was seized last weekend. It was a major pain to break it back free.
I'm what what do you have to alter the trackbar bracket ? I'm building my hp30 using the Barnes coil bracket kit so I'm curious on what I could look out for !
Here is their bracket. It flips the joint to be double shear with a horizontal bolt. The rockjock track bar is made to be used with the stock vertical bolt bracket. You can either cut the JJ off the bar and reweld it, or modify the bracket.
The bracket also raised my mounting point a good bit so it induced bump steer a little, so modifying the bracket is my best option.
I'm going to take ¼" steel and weld it horizontally betwixt the two vertical flanges and drill a hole through it to mount the track bar. Then I'll need to cut the ends off the bracket to fit the JJ up there. My only concern with doing just that is if the weld would hold up to the stress that bar puts on the bracket. I'm sure I'll be fine with hydro assist, but people without may need additional bracing for that small of a flange.
Good luck with that mess.
It's one small 2"x2¼" x¼" plate. Not too bad to weld
An hour fix that you didn't do, yet. Go for it.
I just did a normal oil & filter change along with a lube of the front end parts.
‘No big deal, but I’ve got to say that this “Lock-N-Lube” grease gun is a total game changer. The end is locked onto the zerk so you don’t have to hold it in place. It also never leaks at the zerk & you don’t need 3 or more hands to get the job done.It also seems much cleaner because grease doesn’t get all over everything.
