1. Want to have your TJ featured as the September 2018 "Ride of the Month"? The winner will receive a $200 gift card from Metalcloak! Click here to submit a photo of your TJ. Submissions are accepted until August 20th!
    Dismiss Notice
Discussion in 'TJ General Discussion' started by LJRubiconGuy, Jul 9, 2016.
  1. Don Snelgrove
    Don Snelgrove New Member
    Mar 23, 2018
    13
    14
    Charlotte, NC, USA
    ....Must be a Panthers' fan hehheheeee
    Travis and tomtaylz like this.
  2. tomtaylz
    tomtaylz TJ Enthusiast
    Feb 18, 2018
    541
    549
    San Francisco, CA, USA
    Switched out my black headlight bezels for chrome in the quest to make the white look more balanced (I’ve had them for some time). I plan on putting a washer behind the steering stops later tonight as my Duratracs rub.
    Squatch, Travis, RedrumRH and 4 others like this.
  3. RussinIdaho
    RussinIdaho New Member
    Jul 16, 2017
    4
    8
    Mountain Home, ID, United States
    Dropped it off the get 4.88's, e-lockers, front axle u-jounts, and ball joints installed. Hopefully I'll like the 4.88's with 31's.
    Serbonze, JMT and psrivats like this.
  4. Widawg
    Widawg Member
    Oct 12, 2017
    27
    44
    NM, United States
    Hello everyone! Spent all afternoon tracking down the issue of blower only working on high. Guy at napa told me it couldn't be the blower relay. I had already replaced the blower resistor, so purchased a new switch only to find the switch in my TJ is not like the ones that show listed for it (plastic knob shaft vs shorter metal shaft on mine, also one mounting screw vs 2 on mine). Anywho, guess what, it was the relay all along.
    Thankfully, my fan switch is ok as it apparently unubtainium now.
  5. Kiwi TJ
    Kiwi TJ If people ar talking behind ur back,then just fart
    May 3, 2016
    2,692
    3,788
    Auckland New Zealand
    I painted mine right across including the corners (a few years ago).. that air vent panel just pops out and make it easy to spray too
    #6385 Kiwi TJ, Aug 9, 2018 at 5:21 PM
  6. dimension12
    dimension12 TJ Enthusiast
    Dec 13, 2017
    140
    58
    Prior Lake, MN, United States
    713BD6FB-FE2C-4A46-B01E-D89ADC0A029F.jpeg 40EDE467-DFC2-4124-9BC6-0749E3B0029E.png 40EDE467-DFC2-4124-9BC6-0749E3B0029E.png Changed the shift knob on my 32RH. Will try to get some pics and part numbers this weekend while replacing my 4.0 cylinder head.
    Bought a Gennie Shifter Lo-dapt II for a JK. It fits over the shifter shaft. Used part of a plastic hanger cause the factory one is too short. Instead of pushing the thumb button I just push the whole knob down. Part SKU1051.
    To mount adapter I marked the shift shaft 2.75” up from the console and taped the SKU1051 in place. I then marked and drilled a hole in the shift shaft for the set screw.
    Then I slid the plastic hanger piece into the top of the SKU1051 until it made contact with the factory push button insert and tightened that set screw per instructions.
    Next I removed the SKU1051 and cut off the excess hanger piece. I then tapped the hole I drilled to 8-32 and reinstalled the SKU1051 and the set screw.
    Now just attach a knob and done.
    The adapter comes with 16mm threads.
    #6386 dimension12, Aug 9, 2018 at 5:35 PM
    Kiwi TJ likes this.
  7. JeepZilla380
    JeepZilla380 TJ Enthusiast
    May 30, 2017
    623
    549
    Atlanta, GA
    I’d be an angry jeep too if forced to wear a Pats tire cover!
  8. JeepZilla380
    May 30, 2017
    623
    549
    Atlanta, GA
    Chrome always gets a like from me!
    tomtaylz likes this.
  9. tomtaylz
    Feb 18, 2018
    541
    549
    It does make a big difference, stay tuned for future pictures with the chrome but once I changed my black wheels <plug> still for sale </plug> to moabs, the black headlight bezels stood out like a sore thumb. I think the black/white look is good but with small amounts of black as the white quickly looks out of balance
    JMT, JeepZilla380 and IPerkWVU like this.
  10. Cal
    Cal Member
    Jun 29, 2018
    51
    26
    Hoover, AL
    7784E309-F754-44BC-83DF-EC2BDB579505.jpeg My hinges were faded and beat down by the sun so I cleaned em up and painted them with truck bedliner. (Did the side mirrors also but didn’t take a pic)
  11. Tjrubicon
    Tjrubicon Member
    Oct 29, 2017
    42
    39
    AR, United States
    I’ve been curious what all options there were to strengthen this area. Where did you locate this from? Is it much different/cheaper than an exogate?
  12. RedrumRH
    RedrumRH WNC Asheville Area
    Apr 9, 2018
    87
    81
    Mars Hill, NC, USA
    I like the factory chrome look on mine as well.
    JeepZilla380 and tomtaylz like this.
  13. Nicholas
    Nicholas TJ Enthusiast
    Aug 14, 2017
    350
    273
    Tampa, FL, United States
    Total: 1,400,500 dollars
    Shane Mckinley and JMT like this.
  14. Boinked
    Boinked TJ Enthusiast
    Jul 7, 2018
    407
    337
    Mesa,az
    Nicholas and Shane Mckinley like this.
  15. AndyG
    AndyG TJ Enthusiast
    Jul 30, 2018
    135
    98
    Alabama
    Savvy transfer case cable .
    Works great ,solid engagement in all modes , 9 times out of 10 , but occasionally feels like it binds or something..
    My guess is it's the transfer case just being fussy
    Any one had a similar deal? All's tight and adjusted , engagement is dead on at the transfer case lever .
    JeepZilla380 likes this.
  16. Vcook
    Vcook Member
    May 21, 2018
    52
    45
    Chicagoland
    It’s literally the exact same thing as the exogate, and the good news is I didn’t strip that last bolt hole after all. Project done!! Edit, extreme terrain had the best price I found
    Tjrubicon likes this.
  17. JMT
    JMT The Jeep Guy
    Supporting Member Ride of the Month Winner
    Feb 27, 2017
    4,962
    4,581
    Texas Hill Country, United States
    Wanna sell me your black bezels?
  18. Shane Mckinley
    Shane Mckinley Zipman35
    May 31, 2017
    508
    289
    Oxford, MS, United States
    I’d like to see the mirrors done in Berliner... they just kinda look plain to me sometimes. Maybe it’s the size? I feel like the texture would help
    2005 RHD TJ Sport
    2010 BMW 528xi
    Cal likes this.
  19. Vcook
    Vcook Member
    May 21, 2018
    52
    45
    Chicagoland
    drained and replaced trans fluid, shifting much better!
  20. Cal
    Cal Member
    Jun 29, 2018
    51
    26
    Hoover, AL
    C56137E3-1E25-4EEC-8174-5B9350335BC8.jpeg 7BC31517-D548-4F6F-9A65-E2B78153790D.jpeg DFDA21CE-A720-4E39-8A29-2D9163E641D1.jpeg
Share This Page
