Ephry73
Built a new seat base that lowers me an inch and a half. That way My head isn’t so close to the roll bar. When I added the PRP seats to the factory flip and fold base with the adapters it raised the seating position and being 6’5” tall I felt my head was too close as I couldn’t run my fingers between the roll bar and my head.
Pictures of the base.
Reactions: L J
U8MYDZT
North San Jose
How did you paint your TJ? Looks pretty cool.
I actually got it this way. I was on the fence about it at first but the uniqueness has grown on me. It was done in Raptor Liner. It's a bed liner you can spray at home and tint with conventional paint tints to get any color you want. From what I have seen its pretty easy to apply and repair.
Reactions: Shamu and Fonz54
wyorob
commiefornia
Finished the SYE and put the transfer case from -2" back to normal height, and swapped the upper control arms/set rear pinion angle.
Took a quick trip around the block and holy hell, it's not even recognizable as the same vehicle it's so smooth! I dropped the tcase from -1 to -2 while I was getting the funds for the sye kit,and that made it way better but this is so smooth I had no idea it could get this good.
I can't believe the PO was driving it around the way it was and just accepting it😝
Daubie3
Noblesville, Indiana
OK, so technically not just today, but I've been a little lazy in keeping up to date as I have been doing things for my HEMI swap..
I finished up the refresh on the engine, got a transmission and put in new filters and seals and cleaned it up, then today I did get it mated to the engine so it's pretty much now just waiting to be transplanted in the Jeep..
Also today I did strip my half doors to send them to my Buddy's body shop to get paint matched.
Just trying to stay productive while on home detention during the virus issue..
Fouledplugs
TJ Expert
Alabama/South Carolina
View attachment 148431View attachment 148432View attachment 148433View attachment 148434View attachment 148435View attachment 148436
View attachment 148437View attachment 148438
Looking great!
Reactions: Daubie3
Frankred
Tulsa
I attempted a body lift but started at 9pm after a long (side hustle, now my only hustle) work day. My TJ is now my DD once again. I was finishing up my body lift. The last puck was the front/center location under the grill. However, the bolt hole doesn't line up and the bolt won't start threading in. I left the body mount out for the pic so it is easy to see the offset. The others were fine. See pics of the center puck as well as an example of the rest which are straight - front left.
Has anyone run into this?
Reactions: Vasq
All 4 Wheelin'
Washington State
View attachment 148449View attachment 148450
Try loosening the fender to grill bolts on both sides and see if you can get the adjustment you need. You could also loosen the rest of the body mount bolts and get a little more adjustment.
Reactions: Blondie70 and Shamu
