I've always felt 5 lugs equal 5 spokes, 5 holes, 5 .... And yes, I think you are correct.I think those are probably Mammoth Boulders
I recently painted my stock wheels black. It was a lot of tedious prep work, but the end product was well worth it. I used Duplicolor wheel coating in case you are curious.
Just added my new tires and wheels, grandsons like them
Mammoth Boulder wheels, 15x8 & Mickey-Thompson tires 32/11.5
MT now have a 100.00 dollar rebate, I took it out yesterday
For a drive, very nice ride so far.
What brand are those storage boxes?
I kind like the MT wheels.So far I replaced all factory shocks with rubicon express mono-tube shocks. In the process I broke 6 bolts. I then picked up some Moab wheels that I’m replacing my old Mickey Thompson wheels with. The PO had put 33” tires on it with 3.73 gears so when I’m in 5th gear I essentially cannot accelerate at all. Today I’m picking up some new milestone Patagonia’s to put on the moab wheels. I also put on a new rubicon express steering stabilizer. Last things on the list of to-do’s is remove the 3” body lift the po installed but one of the bolts is just spinning so I’ve decided to take a break for now
Corner notch on the outside block isn't right.
Another beautiful black TJ. NiceSo far I replaced all factory shocks with rubicon express mono-tube shocks. In the process I broke 6 bolts. I then picked up some Moab wheels that I’m replacing my old Mickey Thompson wheels with. The PO had put 33” tires on it with 3.73 gears so when I’m in 5th gear I essentially cannot accelerate at all. Today I’m picking up some new milestone Patagonia’s to put on the moab wheels. I also put on a new rubicon express steering stabilizer. Last things on the list of to-do’s is remove the 3” body lift the po installed but one of the bolts is just spinning so I’ve decided to take a break for now
Water leaks are a bee-atch. If it's coming in the front and ending up in the footwells, be sure to check the seam between two body panels at either end of the piece where the windshield gasket is mounted. You have to flop the windshield forward (removed in pics) and lift up the edge of the gasket (also removed in pics) to see the seam.Adjusted my hood. I'm pretty sure that my girl has been hit in the front. There are some water leaks and body panel issues that I am starting to try and straighten out.
Not today but recently installed my Di Tech mirror relocation brackets. This is the best option I have seen for doorless mirrors. I had cheap mirrors that went in the top hinge but they vibrated badly and no matter how much I tightened them they would try to fold at highway speeds. Just a slight bump in the garage or parking lot would move them also. The factory mirrors are the best option and I think these brackets are the best brackets available. These brackets put the mirrors at almost the doors on position. Mounting points are the top door hinge and the top two dashboard screws.
The drivers side did not fit perfect and angles away from the vehicle but that is very easily compensated for.
The passenger side fit a little better but still very satisfied with both.
