What does your Jeep Wrangler TJ weigh?
I'll give an update with the final weight once I finish the missing items.
2) How long have you owned your Jeep?
10 years.
3) What is your tire size?
37".
4-5 gallons of gas, no driver, otherwise loaded with everything that will normally be carried:
Front left (driver): 787.5 lbs
Front right (passenger): 787.5 lbs
Rear left: 612.5 lbs
Rear right: 568.75 lbs (I'm not sure why this is different)
Total: 2,756lbs sprung weight.
Shipping weight on the axles was 860 lbs (includes 2 pallets, but I've added brackets), 31lbs per rim, and 73lbs per tire. So I think it's safe to say curb weight is around 3616lbs. I'll have to verify some day at a scale.
I stand corrected. I placed my Jeep on a scale today and it read out 4860lbs with all of my tools, 10 gallons of gas, and no driver.
Wow! Exactly the same weight as my Jeep above. Makes sense, similar build, but exactly??? What are the chances it would be down to the pound!
Mine has 1-ton axles, 40" tires with spare, 4.0, Atlas 2-speed, Warn9.5Ti, full armor corner to corner and bottom, soft top, dual triangulated rear, stretched long arms, full cage, tools, high-lift jack in rear, and driver.
Front = 2520 lbs
Rear = 2920 lbs
Total = 5440 lbs
Just weighed mine.
1) 4620 lbs with driver, half tank of gas, rear seat, full doors, soft top, and no other cargo. Figure 4500 lbs no driver and full tank.
2) Owned since 2013, stock when I got it.
3) 37x12.5r15
4) Parts
2005 Rubicon 6 speed
Trektop NX soft top
TNT Guardian front bumper, steel
LoD Signature rear bumper/carrier steel
UCF UHC Steel skid plate
Poison Spyder steel rockers/rails
Poison Spyder aluminum front fenders w/ inners
Poison Spyder aluminum corner armor
Steel steering box skid+brace
Savvy aluminum gas tank skid
Currie Steering
Heavy 37" pitbulls on Hutchinson Rock Monsters, all 5.
4" Savvy lift, aluminum arms, body lift, motor mount lift, Tom Woods shafts
Installing a supercharger and putting the hard top on and I'll go weigh it again. Planning for a full cage and possibly some axle trussing in the future. Just keeps getting heavier but moves ok with the 5.13s and 6 speed
I'll update this now.
Did a bunch of work and tried to take some weight out.
Changes:
Swapped steel skid plates for aluminum.
Replaced heavy LoD tire carrier bumper with low profile BFH bumper.
Mounted spare in tub.
Swapped full doors for Mopar half doors.
Swapped Poison Spyder "rails" for CavFab sliders.
Swapped 37" Pitbulls for 35" Baja Boss tires.
Removed all aux lighting and associated brackets.
Installed a full Savvy Mid Arm kit. (heavier)
Finished that S/C installation, sold the hard top.
Forgoing a cage.
Installed PRPs.
Before 4620 lbs
Now 4180 lbs
Changes:
Forgoing a cage.
Installed PRPs.
Before 4620 lbs
Now 4180 lbs
Thanks for sharing. I'll add this as an example here. Comment there if I should add anything to the list.
I've owned my 2000 for 1 year, weighed in at 3,700 with 1/2 tank of gas and no driver, 31 x 10.50 tires. Haven't really added any extra weight except a Hotheads headliner, a sub woofer, ARB single and a bag of tools.
1) 3760lbs empty. No back seat. 1/4 tank of fuel.
2) Got it 6/21
3) 33-12.5-15
4) 3" lift, stock bumpers, winch plate, 8k Warn with rope, rocker protection, UCF no body lift skid, Savvy tank skid and cable shifter, Spidertrax 1.25 wheel spacers, SYE w/ CV drive shaft, Detroit and 30 spline shafts in the rear, and an ARB twin compressor.
Never made a conscious effort to keep weight down on things I build. But starting from stock its easy to keep the weight down if you try :D
1) What is the TOTAL weight of your Jeep? 4,040 lbs based on a certified scale (I'll see if I can dig up my ticket, I know I have it somewhere).
2) How long have you owned your Jeep? 10 years
3) What is your tire size? 35" MTRs with 15" aluminum rims
4) Anything else worth knowing? No AC, aluminum skids underneath, synthetic winch rope, no back seat, steel highlines with aluminum inners, dirtworx rear bumper and a chopped stock front bumper.
OEM Rubicon Lockers (switches bypassed)
4.5" Rubicon Express 225# springs.
Rancho 5000x
Currie CorrectLync
Nth Degree TT
MML 1.25" BL
Motive 5.13 Dana 44
Revolution Axles
BMB BBK
SwayLoc
Rock Hard Hard Hat F/R.
35 x 12.50 x 15 Cooper Evolution MT
Vision Manx 15 x 8 x 3.75
Rock Hard Cage
Currie Front Winch Bumper w/flat tow attachments
Currie Rear Tire carrier bumper w/RH gas can rack.
Toyota Headlight Kit
Cheap Amazon LED Reverse Lights
AuxBeam LED Flamethrowers
UCF Aluminum Belly Skid
Savvy Gas Tank Skid
Savvy Sliders
Poison Spyder quarter guards
Wide-ass 7" Flares
Currie Control Arm guards.
Toyota Headlights
TeraFlex hand throttle
JVC BT/USB head unit
Ruff Tuff tactical seat covers
HotHeads floor insulation
BedRug
Mustang Cobra Dead Pedal
Wouxun GMRS 30w
Picture and fatass weight is full tank + 5gal, 2 gal water, recovery gear, fluids and on and on... way too many tools.
Gonna downsize for Moab and will be topless.
Other than the one on tons I'm the fattest. 🤔
5280# with my lard ass in it.
  • Wow
Reactions: Wildman
