I am getting a good size lift kit in the summer here in a few months. I am curious of what all I will need to be getting for me to get it all done and over with soon as I start the buying process. I am considering a Rubicon Express 5.5" Tri-Link Long Arm Suspension System from Quadratec. It says I will be receiving all of these components:
GEN2 DISCONNECTS
SWAY BAR END LINKS REAR
COIL SPRINGS FRONT
COIL SPRINGS REAR/PAIR
BUMPSTOPS FRONT
BUMPSTOPS REAR
BRAKE LINE REAR SS
BRAKE LINE SET SS FRONT
TRACK BAR FRONT EXTREME-DUTY
TRACK BAR DROP BRACKET FRONT
SHOCK MOUNTS WELD-ON
PITMAN ARM
X-DUTY CONTROL ARM FT LWR LEFT
X-DUTY CONTROL ARM FT LWR RGHT
EXTREME-DUTY CONTROL ARM FT UP
EXT-DUTY REAR LOWER ARMS
TRI-LINK REAR UPPER ARMS
EXT-DUTY CROSSMEMBER
TRI-LINK REAR TRUSS KIT
Will there be anything thing else I will need to buy other than this kit to make it a full off road capable but yet still driven on the road 75 percent of the time? Thank you in advance and hope this all made sense!
P.S. I believe it is all stock other than the tires. I am new to the jeep community and I like the redneck look and capability of an off road vehicle.
GEN2 DISCONNECTS
COIL SPRINGS FRONT
BUMPSTOPS FRONT
BUMPSTOPS REAR
BRAKE LINE REAR SS
PITMAN ARM
