What else will I need for a lift to fit 35s?
NDSpeed
Resident Penguin Eradicator
East of beauty, West of plains
my list of mods is fairly complete in the bio
Looking at stepping up to 35”
I know I’ll need new springs and shocks and front brake lines. (Rears already done)
Needed: upgraded brakes.
Correctlync
Rear sway bar
Already installed
SYE,
4:10 gearing calculator says I’ll be at 2000 rpm on 35” at 65mph
And I’ll need new bump stops,
Am I missing anything else minor/major?
Yup, read that in full detail plenty of times.
Just trying to start sourcing the parts. Going through my mental checklist of what all I have left to get.
Front axle and lockers are what I forgot.
What year is your Jeep… I.E. which transmission do you have in there? The TJ has a variety of transmission that will drastically alter which gear ratio would work best. I’m going to lean towards 4.10 won’t be a tall enough gear, but can’t confirm without knowing what transmission.
Correctlync
Rear sway bar
Already installed
SYE,
Why do you need a new rear sway bar? Are you thinking just the links due to the added lift height?
He mentioned his profile. It's all in there.
I was gunna comment too and then remembered that he has a Cummins 2.8 swap.
Reactions: Jerry Bransford
I always forget to look there.
Yeah I’d go deeper with the 6 speed. 4.56 at least, possibly 4.88
That was my first thought also. I guess it just depends where the Cummins 2.8 makes power.
Right now it’s a blast to drive low end. Lots of power.
Kinda sketchy though. Always pulling the front left off the ground. That’s why I was thinking of getting the matching rear sway bar.
  • Wow
Reactions: SvtLdr
Definitely at least 4.88 with the 6 speed, but that's with a 4.0. Not sure the effect with a Cummins 2.8, but I usually don't pay attention to engine anyway when it comes to gearing.
Reactions: TRE3TOP
Correctlync
Rear sway bar
Already installed
SYE,
It's kind of cumbersome going back and forth to your profile and first post. Here's what I think you need if I can remember those two sources correctly (some of these things I think you mentioned needing):
4" springs
Shocks
Adjustable front TB
Adjustable rear TB
Extended rear sway bar links
Transfer Case shifter cable
BMB Brake Pads
Dana 30 4340 shafts (since you plan a locker)
1" MML?
4" springs
Shocks
Adjustable front TB
Adjustable rear TB
BMB Brake Pads
1" MML?
Thank you very helpful. Forgot about the rear adjustable track bar.
The Cummins makes power different than the 4.0 so without really looking at a gear calc chart I'd hold off on recommending gearing.
That seems a little on the low side
I haven't looked at a chart nor do I know the RPM range for the 2.8 so what works for the 4.0 isn't going to be the same.
Reactions: SvtLdr
Using the calculator. The 4.88 would put me at 2500 rpm at 65mph
