this is how it should look.. your piece your holding goes toward the top above the hub.. I imagine it was not set in place correctly when put back together and it fell out
No other issues, both sides installed just like in picture. Park brake was working as always.
Driver side is fine, right side side is this, litteraly just fell out.
Did not fight with it when putting back together, so yellow spring is definitely wasn't as compressed as in 2nd pic. Simply took white springs off, spread the pads, fit the fork back in there, applied tension with pads and snapped white springs back in place.
It was a pic I pulled off the forum, but you are correctJust FYI, I believe the yellow spring over the bar that fell out is backwards. Installed like the picture it will not provide any tension, and probably will allow the bar to fall out.
You can see below that the small end of the spring is on the inside edge and it compresses to hold that bar in place.
But if you look carefully, the yellow spring is over the correct end. Now, maybe it's not the correct spring.
