What have you used SEM trim paint on?
MikekiM
East of Montauk, NY
I bought a few cans of the SEM black Trim Paint a while back, based on recommendations here.
I’ve never used it.
If you have used this paint, I am curious what bits you have used it on…
L J
lights before lockers
I haven't used Trim Black but have used quite a bit of Color Coat. I'd use the Trim Black on any black trim pieces such as mirrors, license plate mount, milk jugs, sway bar cover, etc. I recommended following the prep procedures and SEM soap, plastic prep and adhesion promoter.
Reactions: SSTJ and MikekiM
Mike Z
What now little brother…
Lifetime Supporting Member
USA
I've used the Landau Black on fender flares. Turned out really nice.
Reactions: SSTJ
JMT
Saxum Erepo 🪨
The sound bar and exterior door trim pieces. Make sure and scuff the piece, use an adhesion promoter, then paint with SEM. Actually, for better results follow exactly the procedure they recommend.
Reactions: MikekiM
MikekiM
MikekiM
East of Montauk, NY
I did the door latches with Krylon two part, paint/prime in Satin Black. Came out amazing. Minimal prep other than scuffing and cleaning. Truth told, this two part paint is why I have not used the SEM Trim Paint
Andy-WhiteTJ
Poughkeepsie, NY
Reactions: MikekiM
SSTJ
Inexperienced Overthinker
South Carolina
I have not used Trim Black, but I do use Landau Black on just about any plastic or vinyl piece that I want to restore. Like others have said, and like you probably already know, it's all in the prep.
LONGJP2
TJ Expert
Illinois
Any recommendations for removing paint from plastic?
More specifically, I want to remove the Sahara gloss black from a set of fender flares.
Wtrask
Maine
Your better off to scuff it with an abrasive and paint them. Use a red scotch bright and or plastic scuff I think it’s called from napa. Then paint them.
SSTJ
South Carolina
I did that recently, and used a Scotch pad.
