Finally got the UCF skid after waiting a bit. I'm in the NY area( Just north of NYC) and the roads get salted/brined with some nasty stuff. I don't want to have the skid plate self dissolve after a winter or two, much less start acting up against the frame and screws with the salt and making some other issues, or worse corrode at the weld points and become a rattle party.
I'm thinking clean, where I can, with 0000 steel wool where I can and self etch primer the whole skid and then add KBS or POR top coat, or even POR Gas tank sealer just to make sure the inside will stay salt free. The outside(the side facing down) will obviously be easier to clean and maintain, so my main focus is the inside that can hold salt and water longer.
For the outside part I will just top coat it after the self etching primer and touch it up and clean when needed. Or am I overthinking this and I should just use some seam sealer between the frame and the skid and just call it good? Anyone from the NE or rust belt with a UCF Aluminum skid and what long term changes/effects have you seen after a winter?
E
E
