OK, Thanks!A partial change is easy and clean. Take a turkey baster and suck out fluid and replace. Run for a day and repeat. Technically not a flush or complete change, but dilutes.
I'm assuming that it is the ATF+4 Transmission Fluid?ATF+4 is what you want.
Gonna ask this exact question in a week or so. What fluid for an '06 Rubi?
Goatman said:. . . Goatman would seem to be in the camp of answering the question that was asked. . . .
My Power Steering Fluid is pretty dark and probably needs to be flushed and replaced. I've never done this and was wondering the best way to do this.
My Power Steering Fluid is pretty dark and probably needs to be flushed and replaced. I've never done this and was wondering the best way to do this. 2004 Jeep Wrangler Rubicon
Flush by jacking front tires, suck out as much as possible from the reservoir, disconnect return line from steering box and then slowly turn wheel full left to full right until no more fluid comes out. Reconnect hine to steering box. Refill reservoir, again slowly turn full left to fill right and back. Make sure you keep fluid in the reservoir. 3-4 times should do. Check fluid level
If ok start engine, then once again slow full left to full right to get any remaining air pockets purged out. Then confirm fluid level, remove jackstands, and you are good to go.
