@matrixman303 @SecondChanceTJ You really don't even need to and shouldn't use the clutch off road. 4L and 1st or 2nd gear will get you through most obstacles. If you get to a spot where your tires lose grip turn the wheel left and right 90 degrees until it finds traction. Here's the big part. If you can't proceed any further turn the jeep off with the key and leave it in gear. This will prevent rolling back and if in water ruining your clutch. If you stall out leave it in gear and you can use the starter to get going again with your foot on the accelerator to keep going.
Basically leave your left food on the floor. Start and stop with the starter motor. It's way easier to replace the starter then the clutch and the starter is built for this. This has been working pretty good for me off-road but takes some self restraint from smashing the clutch in.
