Are those coil overs?…damn you
You're describing backspacing which is a totally different measurement from offset. They are not different terms for the same dimension. And wider isn't always better, a wider track width can make it more difficult in some tight twisty trails as I always favored. I run 4" of backspacing for my 35x12.50 tires which I favor or 3.75" or less backspacing.General rule of thumb is every inch you lift it your wheels need to go out an inch if you lift it 2 inches you wanna go with 1 inch offset…or more,but like you said 3.75 is pretty common…wider the better who wants their tires tucked neatly under their wheel wells and abide the law![]()
The yellow tape measure is directly measuring the wheel's backspace which is the more useful dimension where Jeep and truck tires are concerned. Offset if more useful for car wheels.
I’m at 4.25”, but hope to go to 3.75” or 4” in the future iterations.
Stick with 4.25 if it all fits. Your steering axis inclination is closer to better than those of us with less backspacing.
I've never seen a Jeep appropriate wheel with 4.25" of BS but that'd be a tad too much for a 12.5" wide tire in my experience.I might stick with 4.25". I love the current scrub radius. Drives really well. I only rub the SL and tower a bit, but not worried about it. The sloped profile of the KM3 may help with the current rubbing, but I plan to move away from them back to an STT Pro. Beadlocks would very likely change the backspacing. Coyotes FTW!
The whole reason I questioned earlier was because I’d like to find some aluminum wheels to install my coyote beadlocks on my STT pros.
too bad we're too far apart to trade, lol. Curious though what your experience has been that drives the plan to go back.
