Just installed mine 2 days ago:interest peeked. got info on how to?
considered running the pendant to the inside, but haven't look for a hole to poke it through ...........then it's stuck inside, too.
http://doubleveil.net/jeep/forty-three.htm
Have you had the switch assembly for awhile? Didn't seem like it was available anymore.
Totally available - it just takes 1.2 forevers to get it! "12 Volt Guy" warns potential purchasers that it can take up to 12 weeks - and that's about what it took to get mine, maybe a week or so longer. Adding to that is he doesn't appear to answer emails - there's no "real" way to get ahold of him other than facesuck - which is hardly professional. I guess he's one of the many who thinks the world revolves around that site. You're SOL if you want to contact him and you're not a member there - but his product is well worth the wait...Have you had the switch assembly for awhile? Didn't seem like it was available anymore.
Best advice yet.The most important gear is your brain. Couple common sense with synthetic rope and shackles, and you can get out of anything you will likely get into. Hint, common sense means going with someone else, to help when needed.
Nicely done Z!
nice switch set , but screw all that other nonsense.Totally available - it just takes 1.2 forevers to get it! "12 Volt Guy" warns potential purchasers that it can take up to 12 weeks - and that's about what it took to get mine, maybe a week or so longer. Adding to that is he doesn't appear to answer emails - there's no "real" way to get ahold of him other than facesuck - which is hardly professional. I guess he's one of the many who thinks the world revolves around that site. You're SOL if you want to contact him and you're not a member there - but his product is well worth the wait...
I'll admit to being perplexed at the solenoid hub!nice switch set , but screw all that other nonsense.
There isn't much smart about hacking into your winch wiring. Pull the switch out of the remote, run the cable through the engine compartment and leave the plug hanging just inside the grill. When you hit the trail, plug it in so the switch is hot.Have you had the switch assembly for awhile? Didn't seem like it was available anymore.
I hear you. I wasn't in any hurry - I ordered it and then forgot about it almost until its arrival. It still sat here after it showed up for about six weeks. But if you want/need it in anything approaching "timely", you'll have to piece it together yourself. People who conduct business on facesuck - and especially those who conduct business ONLY on facesuck, annoy me to put it mildly! You order the thing on his website as it should be, but then he expects customers to communicate with him on a walled garden, members only website (of very questionable reputation). Unprofessional and very bad business as far as I'm concerned. OTOH, he obviously has as much or more business than he needs/wants/can handle, so there's that.nice switch set , but screw all that other nonsense.
I think you mean "without a disconnect plug" - and I agree. I took the shortcut of leaving enough wiring under the dash to where I can throw the panel on the passenger seat, but a disconnect plug would be better. I did that with another button I mounted there - and I may add it to this lashup if it becomes annoying, long wiring or no.Don't mount the switch or any switch to the knee bolster with a disconnect plug. It is dumb to have to unwire something to work under the dash.
I was proofing when you posted.I think you mean "without a disconnect plug" - and I agree. I took the shortcut of leaving enough wiring under the dash to where I can throw the panel on the passenger seat, but a disconnect plug would be better. I did that with another button I mounted there - and I may add it to this lashup if it becomes annoying, long wiring or no.
I see that. "Crossed in the mail"... This would suggest that you and I think a lot alike, and that's scary!I was proofing when you posted.
X6 ( I think so far)The most important gear is your brain. Couple common sense with synthetic rope and shackles, and you can get out of anything you will likely get into. Hint, common sense means going with someone else, to help when needed.
I can't un see that.I see that. "Crossed in the mail"... This would suggest that you and I think a lot alike, and that's scary!
*THAT* is fantastic! Thanx for posing it. I may print out relevant sections...Came here to say this. Your brain is your #1 recovery (and survival!) tool, and is the only tool you can count on having with you.
Check out the old army recovery manuals. They're packed with practical info that's a real eye-opener if you aren't familiar with simple possibilities.
Here's a sample: http://www.lastgreatroadtrip.com/wp-content/uploads/2008/12/us-army-vehicle-recovery-manual.pdf
True, someone will have one if it is needed. These are dangerous tools, can knock you silly if you don't know how to use one.Skip this little goodie take the money and buy 2 soft shackels View attachment 286577
