Hey Jerry I can't remove the springs without disconnecting the track bar right? That way you can move the axle further up and down.you won't be able to cycle the suspension without removing the springs.
I have never disconnected the track bar just to remove the springs.Hey Jerry I can't remove the springs without disconnecting the track bar right? That way you can move the axle further up and down.
I've lived in North Dakota (courtesy of the USAF) but I'm not sure I've ever been colder than when I was when stationed in Mississippi when it dropped down into the 30's together with its high humidity. Yowsa it gets cold there!think ill try and plan to do this Thursday or Sat. Cold front came through today in Mississippi and its supposed to be 34 degrees in the morning. Ill prob have this computer out there calling or messaging yall. ha
yes it does. long johns, big coats and wind proof toboggan.30's together with its high humidity. Yowsa it gets cold there!
How much bump stop extension and up travel do you have?I run Currie 4.5 springs and 35s with plenty of clearance no body lift. I’m sure 3” would also work for my rig
When did Currie come out with 4.5" springs for the TJ?I run Currie 4.5 springs and 35s with plenty of clearance no body lift. I’m sure 3” would also work for my rig
LJ rears are a bit longer than the regular TJ. I run them to compensate for my heavy tire carrier.When did Currie come out with 4.5" springs for the TJ?
I think you mean they have a higher spring rate.LJ rears are a bit longer than the regular TJ. I run them to compensate for my heavy tire carrier.
Possibly. But they are 18.25" vs 17.75".I think you mean they have a higher spring rate.
Exactly, a 1/2" taller free length doesn't necessarily translate into a 4.5" taller ride height.Nope. Same rate, Just 1/2" longer free length. This won't translate into a full 1/2" more ride height though. All Currie springs are advertised as either 3 or 4". But there are some "secret" options to fine tune the actual final heights on either end.
17.75", 79lbs/in combined
https://www.currieenterprises.com/ce-9131rh2p
18.25", 79lbs/in combined
https://www.currieenterprises.com/CE-9131RH3P
It doesn't necessarily translate into that but we have all 3 rear springs here most of the time and we dial in ride height up and down as needed by swapping in the various options since the 1/2" taller one would give a normal TJ with stock rear bumper, no back seat and a soft top about 7" of lift over stock.Exactly, a 1/2" taller free length doesn't necessarily translate into a 4.5" taller ride height.
