T_Hase89 TJ Enthusiast Supporting Member Joined Jun 18, 2019 Messages 504 Location Southern Illinois Nov 18, 2019 #1 What is this washer bit between the seal and bearing? Removed the axle because I need to replace the seal anyway but this through me off. I’ve not been in a 44 rear before so not sure if that’s normal... Your browser is not able to display this video.
OP T_Hase89 TJ Enthusiast Supporting Member Joined Jun 18, 2019 Messages 504 Location Southern Illinois Nov 18, 2019 #2 If the video won’t load... little ring / washer bit my thumb is on.
rubigold TJ Enthusiast Supporting Member Joined Mar 22, 2019 Messages 109 Location Connecticut Nov 19, 2019 #3 part of the seal? Reactions: T_Hase89
tworley Ignored :( Supporting Member Ride of the Month Winner Joined May 23, 2018 Messages 8,328 Location Arvada, CO Nov 19, 2019 #4 X2. That is part of the oil seal. Looks like yours has come apart as that should be one piece (the two parts your finger is touching) Reactions: T_Hase89
OP T_Hase89 TJ Enthusiast Supporting Member Joined Jun 18, 2019 Messages 504 Location Southern Illinois Nov 19, 2019 #5 Thanks. Seal without that part looks like a normal seal I’ve installed in various applications before so I wasn’t sure lol
Rob5589 Certified video trained differential rebuilder Supporting Member Joined Aug 29, 2016 Messages 6,691 Location W Sacramento, Kalifornia Nov 19, 2019 #6 That ring holds the bearing race in place. They generally separate upon pulling the axle.
