Raising the pinion increases ride height. A tummy tuck will add ride height in addition to what normally occurs from the spring lift. An LJ requireds less of a raised pinion than a TJ.
Serbonze is 1.625" taller than I am. Tire wear, load range, and pressure certainly play into that, but are his rear springs as goofy as mine are?
How the little differences add up is interesting.
What do the springs measure at ride height?6 inch Nth Degree lift
37” Pitbull Rockers @ 22psi, 65% tread
22-3/8”
Notes: Ride Height is lower than expected due to all steel full corner armor, tummy tuck, full size spare, 9.5I winch, etc. No aluminum anywhere.
15" Hub height
Define goofy...if you mean airbags and all that, then no. They are standard Currie rears and the upper perches have not been relocated.
Tires are load range c at 26psi.
Based on the above post, I should also say that I have a nearly empty gas tank. I do have a relatively light Jeep and the Currie springs gave me 4.5" of lift front and rear.
Correct.If I remember correctly, a Jeep engineer responded to this question once and said that the Rubicon suspension height is identical to the regular.
Speaking of raising the pinion, if using the control arms to do it, are you also sacrificing wheelbase?The bags are empty. The key is that my spring seats are further apart than most others. That decreases the ride height. My intention in doing this was to build is some height adjustability while running the longer LJ coils. My guess is that I lost about an inch, which I restored with the spacer.
My gas tank is also full. But that only changes the ride height by about 3/8". My Curries also gave me an even 4" on average. That's another reason why we should be posting the actual measurements for this, rather than the advertised lift height and tire side wall sizes. See Daryl's post as another example.
The reason a raised pinion adds ride height is because the axle side spring seat sits forward of the axle tube. Raising the pinion tips the seat and lifts the spring.
How else would raising the pinion be done?Speaking of raising the pinion, if using the control arms to do it, are you also sacrificing wheelbase?
