What options do I have for getting rid of the cat?
duckalot
North Missouri
I haven't done any research yet but my Cat seems to be shot, making a horrible rattling sound in side and the muffler needs replaced too.
What options do I have for getting rid of the cat? Inspections or emissions in my area are not a problem.
Thanks
Chris
Administrator
Staff Member
Florence, AZ
Do you live in a state with emissions or inspections?
If not, you can remove the cat and tune it out via HPTuners MPVI2 software.
This is what I did on my TJ. No check engine lights, no issues.
However, I live in a county with no emissions or inspections.
CodaMan
California Prisoner (for only a while longer)
California (for now)
Okay, I'll say it. It is 100% against the law in ALL 50 states to remove a catalytic converter on any vehicle driven or parked on a public road.
Reactions: freedom_in_4low
Wildman
Over Analizer Extraordinaire...............
In the hills of WA
It has always been my understanding that you TECHNICALLY are not allowed to tamper with any emissions equipment. Just like by federal regulations you have to use the same or new year engine if you want to do a engine swap. I'm no EPA lawyer and I am sure no one is going to run around crawling under your rig to see if you have all your emissions equipment unless you live somewhere that requires it.
I guess I would ask what advantage is there in removing the cat? Or any other emissions equipment? I know in the 70's and 80's you wanted/needed to because it affected performance but was under the impression that wasn't the case anymore.
Reactions: L J
jodomcfrodo
Antagonist and Dick
Illinois
Take it off, jam a stick through it, bolt it back up. That’s how some high school friends used to fix their broken cats and pass visual inspection.
If that idea doesn’t appeal to you, which it probably shouldn’t, I’m fairly sure you can just remove the third cat and put a straight piece in without any issues. I’ve considered doing that to get a little more sound, but I haven’t done it yet.
Jerry Bransford
TJ Guru Moderator
Staff Member
Escondido California
1990 Clean Air Act extended the anti-tampering provisions to individuals
I just researched that and you are correct. BUT if you live in states without smog tests, it's a moot point. The Feds don't have roving teams of FBI agents looking for missing or defective catalytic converters.
Reactions: pagrey
Jerry Bransford
TJ Guru Moderator
Staff Member
Of course not. It wouldn't be the FBI. It would be the EPA SWAT teams.
:LOL:
Damn you're right, I found a pic of the EPA's SWAT team! :ROFLMAO:
WallyWest
PA
They do exactly that for commercial trucks. And I have not seen it myself but have heard from several people in the hot rod, custom builder, scene that feds occasionally show up at their events checking exhausts.
Reactions: Wildman
