Good day all.
2001 TJ
I have the gas tank off to replace the gas tank skid plate. While it is off I noticed the rear track bar has some jiggle play on the one passenger side bushing.
Is that bushing replaceable or do I have to replace the entire rear sway bar? Could it be just the bolt?
Would you advise to do it or is it not really that big of a issue?
also does the fuel pump in the tank have a filter sock on it that I should be replacing while it is out? anything I should be aware of before I try taking the fuel pump out?
Or should I just leave it as it is. I haven't had any issues with fuel delivery.
Anything else I should be addressing while it is off?
Thanks!
Sent from my XT1575 using Tapatalk
2001 TJ
Thanks!
