What should I order from Summit?
MikekiM
TJ Expert
East of Montauk, NY
Need to buy a set of seat bushings. Should have added them when I ordered the seat cushions.
Tell something cool or very useful you've ordered from Summit.. Need to spend another few bucks to get over the shipping charges.. :p
Reactions: Don Bulee
I've used this on the TJ and the Accord so far and haven't spilled or splashed out a drop of coolant. I think mine was the Lisle version, but it appears to be the same kit with different label. Makes burping easy and no mess.
Save the money you want to spend at Summit to use when something breaks.
Something did break... the seat bushings. Figured it would be easy to find enough stuff to order to waive the shipping cost. $13 shipping on a $20 item is a bit irritating. Can't find anything else I need though.. so not much choice but to swallow the shipping fee.
Any consumables that you routinely buy elsewhere, that you could order from Summit this time? Motor oil, gear lube, 10mm sockets, other shop supplies? I find Summit to typically be bit more expensive that other sources for stuff like that, but if you can eliminate your shipping expenses in this case perhaps you could come out a few bucks ahead.
