What tire inflation system do you run?
ARB CKMA12 Air Compressor High Output On-Board 12V Air Compressor
Mounted on the ABS tray. Currently just for air up but figured I'd future proof the install for if/when lockers are installed.
Reactions: GaTechTJ
I've switched from a 10lb C02 tank to a converted Sanden 709 ac compressor for on board air. The sanden fills up my 35s from 8 psi to 25 psi in 70 seconds. It does require an oiler and coalescing filter though
Reactions: ac_ and jjvw
I used a Viair 88p for many years. It was slow, but never let me down. My York has been in for 3-4 years now and has been great.
Reactions: alittleoff
Does anyone have any experience with the Warn winch power plant? I need a winch and compressor and this winch has both. Not sure how good the compressor is on the winch ? It’s listed for $750.
I believe that particular winch puts out 5CFM @ 90psi. Not bad if the google search is right. I dont know enough about the OBA winches though
Reactions: 06TJ35's
How heavy is a Powerplant?
A nut busting 100 lbs!
SPECIFICATIONS:
Rated line pull:
PowerPlant 9.5 9,500 Lbs., (4310 kg)
Motor: Series-wound 4.6 hp 12V, with thermal protection shutoff switch
Electrical controls: Contactor Remote control: Remote switch with thermometric LED and 12 (3.7m) lead
Gear train: 3-stage planetary
Gear ratio: PowerPlant 9.5 156:1
Clutch (freespooling): Sliding ring gear Brake: Automatic mechanical cone brake
Wire rope: PowerPlant 9.5 125 of 5/16 (38m of 8mm diam.)
Fairlead: Roller
Recommended battery: 650 CCA minimum
Battery leads: 2 gauge, 72 (1.83m)
Finish: Flat black powdercoat
Drum diameter/Length: 2.5/9 (6.4cm/23cm)
Weight: PowerPlant 9.5 100 Lbs. (45 kg)
