Now stop me if this discussion already exists, I can't find it. Anyway, just wondering what oil I should use during a jersey winter. I have 118k on my 4.0 stock motor.
I think this is the first oil thread for this forum! You broke our cherry!
I use 5W-30. I don't care about the brand as long as it's a major brand.
The owner's manual does not specify conventional or synthetic oil for the engine. Either works fine in non-extreme cold weather conditions, conventional is less expensive and does an excellent job at protecting our engines. The only time that synthetic becomes worth its extra cost is if you're in extremely cold like sub-zero winter conditions like in in Alaska, North Dakota, Minnesota, Buffalo NY, etc.ok here is the noob question... are we discussing synthetic or real oil? I don't know what is standard for mine, i read my manual when i first got my jeep, but i am stuck in the office right now and can't grab it to go check...
Some manufacturers recommend, but do not require synthetic. Dino oil is, as Jerry has said, plenty sufficient for proper lubrication. If you live on the North Slope, Iceland, or the U.P. in Michigan there are times when synthetic makes sense.
Save the money for something else, like a really good oil filter. Or halo's for your headlights.
You have succumbed to Amsoil's misleading oil life claims... what you don't realize by not changing your oil at the intervals recommended by Jeep is that your oil FILTER gets just as dirty as with any oil and you're leaving it in past its useful life. Engine oil picks up dirt, contaminants, naturally occurring acids, combustion byproducts etc. at the same rate no matter what the quality of the oil is. By leaving the oil filter in 2X as long as it should be you're asking for the filter to go into bypass mode.I spend $40 for 6 quarts of amsoil and their oil filter. I run it for 9 or 10k miles.
