Gomer should know OP is always checking for leaks!!! And I did prior to posting this. How often do you find yourself eyeing the underside of the engine compartment right after you park and your walking away from your Jeep? Checking if anything's leaking? Do it all the time. The leak wasn't obvious.
Like I said, I decided to let the engine warm up, at idle, to operating temp. I noticed the leak happening, just at the moment the temp. gauge reached 185-195. Then the temp gauge went up to 210 at idle, then went back down to 195. As soon as the temp. dropped down the leak stopped. I seems like the thermostat isn't opening when it should. It's just a guess. I did check the level in the expansion bottle and it looks to be full.
1) If the level in the expansion bottle is too full could that cause a problem?
2) Is the upper radiator hose connected properly? Should the hose go to the first STOP or the 2nd STOP, which is further down the hosing.
