Fastener torque depends on yield strength of the material in the stud or bolt, think of it like a paper clip, bend too much, it breaks. The threads tighten down to the point where the fastener stretches a bit. If it’s stretched too little, it will loosen, if it’s stretched too much, it will permanently deform. That’s why I don’t like the shops that run the nuts up with an air ratchet (un-calibrated) and then just check with a torque wrench. Sure, you know they’re at least tight enough but are they over tightened?
Also, it’s good to not have any extra friction in the mix so you know the torque is mostly being applied toward stretching the fastener.
On really critical fasteners such as nuclear reactor heads, they have a hole drilled in the middle of the stud and stretch is measured with a depth micrometer. No torque wrench needed.
So on the 35’s, assuming you have the same stud material, the torque remains the same. More torque just moves you closer to yielding the fastener permanently.
