1. Want to have your TJ featured as the March 2018 "Ride of the Month"? Click here to submit a photo of your TJ. Submissions are accepted until February 20th!
    Dismiss Notice
Wheel measurements
Discussion in 'TJ Wheels & Tires' started by CybrSlydr, Feb 13, 2018.
  1. CybrSlydr
    CybrSlydr TJ Enthusiast
    Thread Starter
    Jan 17, 2018
    164
    73
    Beverly, OH, United States
    So, what I'm familiar with when it comes to tire sizes is apparently quite different than you folks.
    For example, my M3 has 18" wheels - 225/45R18 in the front and 255/40R18 in the rear.
    Now, I look at the wheels/tires on what you folks are driving and you're talking about 31s, 33s, 35s, etc. Obviously this isn't the rim size, which is what I'm used to. I assume this is the radius of the tire?
  2. JamesAndTheSahara
    JamesAndTheSahara TJ Addict
    May 22, 2017
    1,963
    1,640
    Auburn, AL, United States
    They are talking in plain terms. You can “usually” assume when someone is talking about 35s (35x12.5r15), 33s (33x12.5r15/33x10.5r15) ect. You will find users on here running a metric size tire usually run a 16” rim. Most people running a 15” rim get quite a few more tire choices.
    Chris, bobthetj03 and CybrSlydr like this.
  3. Ranger_b0b
    Ranger_b0b TJ Addict
    Feb 28, 2017
    1,694
    1,709
    Or, you can be weird like me, and go to a 17" wheel. Things get more "metric" with 17" For instance, I'm running a 255/75R17, which roughly equates to a 32" (diameter) x 10" (Section Width) x 17 (Rim Diameter)
    CybrSlydr, bobthetj03 and StG58 like this.
  4. StG58
    StG58 Backwoods Amateur
    Oct 29, 2015
    5,018
    4,720
    Orygun, the wet side...
    ...or a 285/75R16 which come out close to what we'd refer to as a 33x11.25R16. (That's not a real tire size) There's several good tire size converters on the Web that will make translating much smoother and easier. Most, if not all, tire that are called out as a diameter and width, like 31x10.50, are LT or light truck tire sizes. It's a left over from the bad old days.
    CybrSlydr and bobthetj03 like this.
  5. Rob5589
    Rob5589 I'm a dude playin a dude disguised as another dude
    Aug 29, 2016
    3,325
    3,022
    W Sacramento, Kalifornia
    31x10.50 R15 is a 31" diameter tire with a 10.5" section width on a 15" diameter wheel.
    A 225/45 R18 is a 255mm section width with a sidewall height that is 45% of the section width on a 18" diameter wheel.
    "R" is for radial. Letters like S, H, V, M are speed ratings.
    Makes perfect sense, right :D
  6. CybrSlydr
    Thread Starter
    Jan 17, 2018
    164
    73
    lol Yeah - problem was I'm going from a vehicle where actual tire size (31, 33, 35, etc) is irrelevant and what you use to talk about it is the rim size (yeah, I got 18's on mine, yo... slammed on 19s is dope, etc).
    Like switching from Imperial to Metric. :D
    StG58 likes this.
  7. bobthetj03
    bobthetj03 TJ Expert
    Feb 3, 2017
    4,103
    4,103
    Lake County, Northern California
    LT is light truck. "C", "D", "E" are tire ply ratings. A "C" tire is a 6 ply, "D" 8 ply, "E" 10 ply. Most 16", 17"Jeep metric tire sizes are either "D" or "E" load tires. An "E" load tire has a stiffer side wall and can cause a rougher ride as a result cause our jeeps are light for that load tire, so you'll often see folks recommend a 15" wheel with a "C" load tire.
    CybrSlydr and StG58 like this.
  8. Chris
    Chris Administrator
    Staff Member
    Sep 28, 2015
    20,822
    11,241
    Salem, Oregon
    Wheel tire sizes don't make any damn sense with TJs. 15" wheels get you tons of 31", 32", 33" and other standard sizes. While 16" and 17" wheels get you metric sizes. I can't make sense out of why it is the way it is, but that's just how it is.
    For what it's worth, this metric tire converter is a very useful tool in my experience:
    https://tiresize.com/metric-tire-conversion/
    StG58 likes this.
  9. bobthetj03
    Feb 3, 2017
    4,103
    4,103
    If you brought over our jeep logic to your Beamer lingo, then you'd be slamming on 255's brah!
  10. Rob5589
    Aug 29, 2016
    3,325
    3,022
    Just a little more reading material for ya :D
    CybrSlydr, StG58 and bobthetj03 like this.
Share This Page
