Wheel spacer question
SgtMajor138
Long-time Jeeper
Glasgow, KY
After putting on a set of 5 spoke Jeep wheels with 32x11.5x15 BFG KO tires, my front tires rub when turning (DUH!). I also added a 2" coil spacer lift which obviously did not help that issue, but did help the looks. :)
In an attempt to fix the problem, I just purchased these 1.5" spacers
When I added the spacer to one of the rear wheels, I noticed that the lug nut would only go on the spacer about 5 or 6 threads. It is the same for all of the spacers. The studs on the spacers are about a half inch longer than the wheel studs - 1" vs 1.5". I only noticed this due to the spacers having open end lug nuts. After further review, my current lug nuts are actually only on about 5 or 6 threads.
Should I replace all of the studs on the Jeep with longer ones before adding the spacers? This Jeep will not be doing a lot of off roading but I would hate to lose a wheel at 60MPH.
Thanks in advance for any help.
pagrey
Los Angeles, CA, USA
I don't know if you can run acorn lugs on spacers, the nuts that hold the spacer to the Jeep. I'd get the correct length studs. Just measure so you can match the front stud length. I had to get new rear studs, it isn't too difficult after you get the axles out. Mine were Dorman 610-449 1/2-20 Serrated Wheel Stud - .627 In. Knurl, 1-15/16 In. Length but you might need something different depending on what you have now.
Nothing wrong with extended if you can find the correct ones, I'd just do it the other way, cheaper too.
