If I were to remove the rotors on my 2002 TJ, install 2" lug centric spacers, and reinstall my rotor on to the spacer lugs, am I making a mistake? Is there anything I'm missing that would make this a BAAAD idea?
Give it a try and let us know how that works out for you.......
The spacer goes on after the rotor is on.
was this intended to be helpful? I'm here for legitimate support...
If you take the rotor and remove it from the braking system is that a good thing? Its what you suggest.
He said: "If I were to remove the rotors on my 2002 TJ, install 2" lug centric spacers, and reinstall my rotor on to the spacer lugs..."
The rotors will no longer fit in the caliper if you put the space in before the rotor
I’m curious what is driving the desire to run the spacer inside the the rotor?
To make it very clear, NO, you cannot install the spacers first.
If you did, the caliper/pads would no longer be able to contact the rotor so no front brakes.
If you're using spacers, be sure to torque them to spec and use blue thread locker.
Drive it a couple hundred miles and then check the torque on the spacers again.
Aside from all of the snarky comments that will inevitably compromise the effectiveness of this forum, i appreciate the responses.
I'm just gonna pull it apart and verify. If what I believe is true, is in fact true, my spacers will leave enough space on the rotors for the calipers and pads to sit correctly on the rotors.
if it works, I plan to wish voodoo evil on all the unit-measuring members unwilling to help.
EDIT: If it doesn't work, I'll leave that info here for the next person who has the same curiosity.
I will offer all my encouragement for you to see what happens. Be sure to report back with your findings.
