When should I be concerned about water dripping from Jeep?
Jared91
San antonio
I just got a transmission overhaul and so far my Jeep has been driving okay but I noticed a lot of water leaking…both when it’s on and when it’s completely off. Is this normal?
  • IMG_6360.MOV
    14.1 MB
Are you sure where the water is coming from? The ac will drip alot of water. During and after driving. See if you can find where its starting from. If its your ac. Dont worry about it.
Reactions: 2001slvrstntj
You may want to check just under your heater core/ ac lines going into the firewall there should be a small tube sticking out. stick a pipe cleaner in there and fish around. you can use some can air as well to blow out anything that could be clogging the drain. if your getting a ton of water even when not running your drain may not be draining fast enough.
My ‘06 TJ really drains a lot of condensation from the A/C even after it’s parked in the garage a good while. We also live near Beaumont, Texas, the undisputed humidity capitol of the world.
bottom line, if you’re getting nothing but clear water you’ve got nothing to worry about.
