Where can I find a Mopar transmission mount?
speedboater
Tampa
Hi guys,
looking for a stock transmission mount 52058551AB and not having any luck finding one. anyone have a good resource for them.
TheBoogieman
Disturbed
C-Ville VA
I've used Anchor motor and transmission mounts for several years with no issues. Saves money too.
Reactions: P man
Jerry Bransford
TJ Guru Moderator
Staff Member
Fleming Island Florida
Tough to find these days. I would just buy an aftermarket mount and be done with it.
The potential problem with aftermarket is many are made with polyurethane bushings instead of a good quality rubber. And some that are rubber use such a cheap stiff rubber that they readily pass vibrations into the cab so they might as well be polyurethane.
cpwolf
Texan
TEXAS - Cedar Park
Hi guys,
I actually have one, and I'm
Hi guys,
I actually have one, might want to message me
cpwolf
Texan
TEXAS - Cedar Park
Hi guys,
Was going to Install, but I got the Savvy Under Armor, and will be putting that on this month.
Reactions: SkylinesSuck
P man
Keister Bunny
Washougal Wa
Not much other choice and I agree on the rubber vs poly...I do occasionally get some decent used ones guess I will quit throwing them out
Reactions: Jerry Bransford
cpwolf
Texan
TEXAS - Cedar Park
Wait, just to be 100%, when I install my Savvy Under Armor this doesn’t get used, it has the rubber bushings in the crossmember right @Jerry Bransford ? Ha
I bought the Mopar Trans Mount then didn’t install yet and pulled the Savvy UA trigger. I haven’t installed, but I’m 99.9% sure o don’t need this trans Mount now.
Mark K
Lifetime Supporting Member
Texas Hill Country
Last August, I replaced the OEM 3550 with a new AX15, but was unable to locate a new Mopar tranny mount. So, I took a chance on an Anchor 2882 from the Am. Has been brilliant. No vibes at all.
Mark K
Texas Hill Country
What exactly is Anchor 2882 from Am?
Sorry, my lack of knowledge?
Anchor is an aftermarket parts supplier, selling on Amazon. The Anchor 2882 is a proper replacement for the TJ transmission mount for manual transmissions. Looks like rubber construction and acts like it. Jerry is right to warn us away from too many other suppliers who use hard plastic. I looked at a bunch of mounts and noticed that the Anchor appeared to be well made, but had to chance the purchase to verify that.
Reactions: cpwolf and Woodrow
DWR
Georgia
Due to circumstances at the time, I had to use one from Orilleys… worked perfectly fine with no vibration issues
Woodrow
Oregon
Same good experience with Anchor. I replaced my worn out stock mount with a parts store mount and had a big increase in drivetrain vibes through the body. This was completely solved by switching to the Anchor mount for my AX-15.
BIGMike
Northern Michigan
Just an update… I placed orders with moparpartsgiant and Steve White only to have both orders cancelled stating the part has been discontinued. Still in the hunt if anyone has an extra they’d care to part with or have another recommendation to chase down a Mopar mount.
