T TwoBags New Member Joined Nov 1, 2021 Messages 2 Location Newmanstown, PA Nov 1, 2021 #1 I bought a 1997 Jeep Wrangler used, and I have to replace the back left window. Where do I look to find the brand name of soft top roof that's on it? The window has a metal zipper not a plastic one. Last edited: Nov 1, 2021
Chris Administrator Staff Member Ride of the Month Winner Joined Sep 28, 2015 Messages 71,051 Location Gillette, WY Nov 1, 2021 #2 Look inside the soft top for any tags with the brand name on it.
dbbd1 go away... Supporting Member Joined Jan 4, 2019 Messages 1,968 Location Oregon Nov 1, 2021 #3 Also check to see if the zipper pull stays on the window (look at your right side window) or does it stay on the soft top. (I may have a spare window)
OP T TwoBags New Member Joined Nov 1, 2021 Messages 2 Location Newmanstown, PA Nov 1, 2021 #4 dbbd1 said: Also check to see if the zipper pull stays on the window (look at your right side window) or does it stay on the soft top. (I may have a spare window) Click to expand... The zipper pull stays on the soft top, the zipper is metal.
dbbd1 go away... Supporting Member Joined Jan 4, 2019 Messages 1,968 Location Oregon Nov 1, 2021 #5 TwoBags said: The zipper pull stays on the soft top, the zipper is metal. Click to expand... That's the kind that I have. With medium large zipper teeth. I'll send you a PM.
