97 TJ 4.0 Manual all of a sudden won’t start. Was running great.
When troubleshooting I found this loose plug. I cannot find where it goes. Not sure if it’s related to my issue. It comes out from the same part of wiring harness that goes to the distributor.
The vehicle turns over but won’t start. It has gas. All fuses good. Swapped fuel pump with horn relay also. Checked battery is good with volt meter. Sprayed starter fluid in the intake and it pudders a bit but won’t start. I jumped fuel pump relay and hear it humming.
Another symptom is I noticed my fuel gauge and volt meter do nothing when I turn the key. Fuel light is lit, Temp and other gauges activate and radio/fans come on. All gauges work when I run a cluster test.
Not sure where to go from here, any advice?
