Where is a reliable place for switched power on a 2003 Rubicon?
jesseshoots
Charlotte, NC
It’s odd but Mopar during these years had really odd electrical things that do funky stuff. My 2006 Ram had some odd things it would do like throw random codes then run fine. 🤷‍♂️
A perfect example of this is the P0123 (TPS hi-voltage) being caused by a bad clock spring due to a shared ground and input into the ecu.
Reactions: AndyG
Mr. Bills
Raconteur Emeritus
San Miguel de Allende, Guanajuato, Mexico
I have found that you can't just tap on anywhere without creating some electrical weirdness... What is a reliable place to tap on to get switched to power on the fuse block behind the glove compartment.
Thanks
Andy
On my '06 I used a mini add-a-circuit at position 18 of the fuse block behind the glove box - marked Cigar Lighter.
It is switched power - I use the tapped circuit to power my Garmin navigator, dash cam and charger for my Garmin inReach.
Reactions: AndyG
Lou
Don’t drink the koolaid
Long Beach
I would use a test light/DMM to locate a switched power fuse in the glovebox. You could then use a fused add a circuit.
AndyG
AndyG
Because some other guys are perverts
Lifetime Supporting Member
Alabama
Cool..that would be a good source..there is a switched and I switched going to those. Thanks, good post.
Jeep 541X
Bend Jeepin'
Bend, Oregon
Whatever you do, do NOT piggyback on Solenoid fuse 11, or you may find yourself without AC like I was while in NV.
