Where is the turn signal flasher relay located?
ScottyZ
Buffalo, NY
Is there an actual flasher unit for the turn signals, or is it integral to the multifunction switch?? My TJ is a 2001. Thanks!
Twopoint
TJ Pupil ... and all it entails...
Lifetime Supporting Member
Kitsap WA
IIRC on your year, it is connected on top of the multifunction switch
98561
TDB55
North Carolina
it is under the dash next to the steering column, turn on the blinkers and listen for the clicking!
Well I finally got all my led bulbs and correct flasher. The flasher is a little hard to get to and bolted down too. It’s not on the firewall per the previous reply
Reactions: Twopoint
Jerry Bransford
TJ Guru Moderator
Staff Member
Fleming Island Florida
Just realize if you replace the side marker incandescent bulbs with LEDs they won't work right with the LEDs. That circuit reverses current flow direction when the headlights are turned on/off and LED bulbs don't allow current flow in the other direction like incandescent bulbs do.
mrblaine
Crew Member
Quail Valley, CA
One would almost think there is a diode involved.
Green Jeep Mantis
New jersey
Hello folks. Im not well versed in auto electric systems. Basically, is there an additional part or parts i need to get to have the marker lights illuminate properly? I bought the flasher relay and LEDs for the rear lights. Do i need anything else for the front? Thanks in advance!
Vtx531
Kalamazoo, MI
LEDs wont work in the front. Light Emitting Diodes.
