Seriously looking at putting a cable operated ox locker in the front axle of my LJ. How/where do people usually mount the shifter? Would love to see some pictures of some installs.
Thanks
Thanks
And if I were to choose an air or electric actuated version, I'd be going with an ARB Air Locker or an Eaton E-Locker. Between those two I'd probably go with the Eaton E-locker.I don't know many people here that run the OX lockers with the cable shifters. From my little experiance with them trying to get the cable routed properly is a HUGE PITA. And now since they offer either a electric or air option most people are using them instead.
Every post here is a personal opinion and I was quite clear that what I said was my personal opinion... "And if I were to choose an air or electric actuated version" that if it was ME doing it I'd make a different brand selection.Yes Jerry we all understand YOU don't like OX but that doesn't mean that others can't run that brand locker.
Have you experienced issues with OX? I’ve never seen anyone run one.Every post here is a personal opinion and I was quite clear it was my personal opinion... "And if I were to choose an air or electric actuated version" that if it was ME doing it I'd make a different brand selection.
I read enough problem stories about the cable mechanism that I knew I didn't want one. That got better with later cable mechanism design improvements but not so much I'd have gone with one. It's too bad too because I had met the original designer of the Ox several times many years ago and followed its development up to the point he had its final design machining done either by a Porsche contractor or something to do with Porsche. At its earlier stages I wanted one.Have you experienced issues with OX? I’ve never seen anyone run one.
So the locker itself is sound it’s just the actuation method?I read enough problem stories about the cable mechanism that I knew I didn't want one. That got better with later cable mechanism design improvements but not so much I'd have gone with one. It's too bad too because I had met the original designer of the Ox several times many years ago and followed its development up to the point he had its final design machining done either by a Porsche contractor or something to do with Porsche. At its earlier stages I wanted one.
I've been running 35S ox in rear and he's it locks everytime I apply air. Also has a thread in lock bolt in case you need a locker and your supply fails. The only downside to ox I found is the diff cover is larger than a stock cover.So the locker itself is sound it’s just the actuation method?
I need to pull my ARB, it’s working but also blowing diff fluid out the breather.I've been running 35S ox in rear and he's it locks everytime I apply air. Also has a thread in lock bolt in case you need a locker and your supply fails. The only downside to ox I found is the diff cover is larger than a stock cover.
That's my impression. One thing for sure, it's a niche locker that just isn't as popular as other brands and when that's the case I have to believe there's something to that. I certainly read of more actuator issues with the OX than other selectables. There are newer selectable lockers like the E-Locker that are already far more popular.So the locker itself is sound it’s just the actuation method?
The diff cover is enormous. Sometimes that matters.So the locker itself is sound it’s just the actuation method?
Yes i wouldnt use one for the front for that reason. For the rear i was able to get all my uptravels thanks to savvy skid and body liftThe diff cover is enormous. Sometimes that matters.
I like mine, front and rear, electric actuated. I haven't measured, but Id guess the size of the cover will be close to whatever other chunky aftermarket cover. I've never had any clearance issues, front or rear.
I think the OX got a bad name in the beginning due to cable issues and never really recovered. The cable has been upgraded, but once ppl make up their mind, it can be difficult to persuade them to change. Reading about others problems or seeing something poorly reviewed from sometime ago is all some ppl need to form an opinion.
Marketing/sponsorship is also a very powerful tool.
I think the ARB is a great locker, however I have no personal experience. As I understand, the OX and ARB are very similar in how they function, with a locking ring.
Eaton also makes a great product.
Ultimately, whose stickers do you want...
They make the rocking world go roundSo you got a FAT Bottomed girl in your Jeep???
That's what I call my truck since it's a dually.
