Where to find a gentex wiring harness for an 03
sam53
sioux falls sd
Morning all. Wanting to place a Gentex rear view mirror in my O3. Of course the wiring is on top of the dash but I am looking for the wiring between there and the mirror, thanks. Also in a you pull it, what mirror are most using?
The gentex mirror would be a retrofit from an early 2000's GM vehicle with the compass and ambient temp sensor. so go scour the local JY's and get the mirror, harness and sensor. Then follow the write up on here.
You are my Hero! Thanks so much. cant believe that harness in a hunk of junk GM is the same as the tj!!
the wire colors may vary but the mirror is the same you may want to double check the connectors too look for the write up in the how-to section just to verify.
