If you choose to buy used/JY you might have to search a little and you most likely won't find one with a grooved pulley unless you got to a semi JY. But you can find them on Ebay with the grooved pulley if you look a little.
What brackets are you going to use?
C U Off Road - Jeep Bracket Kits
OBA-2000 2000-2006 TJ WRANGLER 4.0L with AC $260
This kit will mount the York compressor in place of the alternator. The alternator will be relocated under the compressor.
This kit uses our EF210R (not Included) and 25-513352 serpentine clutch (not included) and a longer serpentine belt which is inlcuded.
The stock belt tensioner has been replaced with a manual belt tensioner system. No squeaky belts!
The stock air box can be used, but it is a tight fit.
This kits fits the 4.0L engines only. Will not work on the 2.5L engines.
10 lbs 12 x 9 x 5
OBA-2100
OBA-2100 2000-2006 TJ WRANGLER 4.0L without AC $260
