You are the first person I've seen on here that doesn't like the Redline in their manual tranny.the Redline absolutely made it worse.
Same experience I had. I never had an issue going from 2-3, but 1-2 usually felt like there was a notch in the way. Ever since I installed the B&M shifter, that problem has gone awayI just put one in my 05 today. I was also having trouble between 1-2 and 2-3. Was like it had to push through something and it would click hard getting into gear. It would go away somewhat shifting extremely slow. But was still an issue.
Now after replacing the shifter it does not do that anymore. The shifts are very short. B&M claims 35% reduction but it feels like 50%. Overall I like it. A bit pricey but worth it to me.
I was skeptical that it would make a difference but I’m pleasantly surprised.Same experience I had. I never had an issue going from 2-3, but 1-2 usually felt like there was a notch in the way. Ever since I installed the B&M shifter, that problem has gone away
I was able to re-use the factory shift handle. No issues whatsoever with a 1" body lift and a tummy tuck.I guess I am going to have to watch prices on the B&M shifter. Can you use the same shift handle or does it require a new one?
That's odd. I had the exact same issue, except it showed up after I put the B&M shifter in. NV35501-2 usually felt like there was a notch in the way
I believe I paid less than $250 for the one I installed in my 2002 about 6 or 7 years ago. Incredible how they have more than doubled in price since that time.
Body lift or tranny drop? I'm in NY and the MTL made a big difference in how much smoother it shifts, but YMMVI recently drained the trans fluid and put in Redline MTL. The redline is coming out and I am going with Mopar fluid at $26 per quart. Shifts into second are VERY hard now when cold. I am double clutching the 1-2 shift and still have a hard time getting it in. It was not exactly smooth 1-2 before but draining out the Mopar fluid and putting in the Redline absolutely made it worse.
IF, you prefer not to return it, you could modify the shaft of the lever so it wouldn’t contact the trim ?I just installed a B&M shifter after the seal around my OEM shifter started leaking. I wouldn't do that mod again. I was hoping that despite it stating that it doesn't work with a body lift, that I could get it to work. I couldn't. Even after removing the body lift, the B&M still hits the trim. I'm not sure why B&M wouldn't make the shifter compatible with body lifts. Worse though is that the shifting is horrible, or at least, I don't like it. It's coming out and going back.
Most people report good things with redline but it did not work for me. At the time I did not have a body lift on stock transfer case.Body lift or tranny drop? I'm in NY and the MTL made a big difference in how much smoother it shifts, but YMMV
