Whole new flasher relay issue
Craig D
Chicago Suburbs
My 2005 TJ recently got the typical hyper speed blinker issue. What came with it, which I had not seen or read about, was a very dim headlight on the same side as blinker issue (passenger side).
I replaced the flasher relay, which fixed the blinker issue. These now work fine. However, I still have one very dim headlight (these are only a year old) and daytime lights not working on same side. And when I turn on the headlights the passenger side interior turn signal light stays on (even when not using the turn signal).
Your expertise is appreciated.
Craig
Look at your headlight terminals and all connections
Mine were rotted and fallin apart
Definitely check grounds
Also can swap the drivers and passenger headlight to see if the problem follows the headlight itself, or the wiring
It was the ground. I had looked at this before and thought it looked ok. This time I did a little sanding and magic, it worked.
I also used it as an excuse to take the chrome bezels off and paint them black!
Thanks for assistance.
