Have a gander below if you would. I was under the TJ the other day for different reasons (cleaning mud) and I noticed three contact marks on the tie rod. One is covered in grease, presumably from the pitman arm ball joint, then there are two more slightly outboard (two marks w/ surface rust). I haven't heard any noises or noticed odd symptoms, but I wonder what could be causing it? Would bump stop settings be a good place to start here?
The TJ has a 4" Procomp lift installed by the previous owner. The only work I have done since purchasing it is installing Rancho shocks to alleviate the previous bone-jarring and filling-loosening ride.
Thanks for looking
Thanks for looking
