Am I in alternate land right now? The arm can't possibly come unscrewed - there is a bolt going through each end of it that is attached to either the frame or the axle. Unless you somehow managed to rotate the entire axle relative to the frame you will never disconnect the two ends of an adjustable control arm while it is still attached to the vehicle.
I'm wondering if perhaps Mr. Blaine meant to respond to you instead of to me...
You are. The threads on DA arms are reverse threaded when compared to the other (one right hand, one left hand). Meaning if you turn the arm one way you’re moving up the threads on both joints, reverse the way you’re going and you’re moving the threads down both joints. This is why they’re valuable, else you need to remove a joint from the rig to adjust them.
If you screw the arm long enough you’re either going to reach the joint housing and can’t tighten any further or fully unscrew them when the arm and the joints are now separate. The jam nuts keeps this from happening by working together to block motion either direction. A single jam nut won’t work nor will no jam nuts.
You conjuring @mrblaine doesn't change your misunderstanding.
