Why is it that I never see outboard shocks on JKs? Is the stock suspension setup in such a way that there isn’t as much benefit from outboarding?
I'll have to study the neighbor's JK. Mount relocations must exist on the JK. Maybe they are able to just move the mounts up. The reason to go outside the frame on a TJ (and probably the YJ, CJ) is because that is where the most room is.
I must be missing something.
It's your Jeep. Only better.
I'm also confused, unless there is something else going on up above.
I see a rear shock that disappears into a cross member like the TJ.
It exists...
I'm also seeing several rear lower drop brackets, which makes far more sense than raising them without doing anything else.
Synergy has a cut and weld raised rear upper to go with their lower extension.
To be fair, outboarding on a TJ isn't particularly common either. I can't think of anyone I know that had done it on a non-truggy build. I know 2-3 that have relocated the rear lowers, though.
I'm not a JK guy, but my understanding is the rear frame width is wider than the TJs. You have to go very wide axles to make it work (coilovers). The JKs can fit longer shocks stock in the rear than a TJ, so I doubt you would do the work to outboard standard smoothie shocks.
I wouldn't call it common but around here I've done so many I can't remember them all. Well over 50.To be fair, outboarding on a TJ isn't particularly common either. I can't think of anyone I know that has done it on a non-truggy build like ours. I know 2-3 that have relocated the rear lowers, though.
