Tap on your location at the top of the screen. Then select add at the bottom. It will open up with every state listed. You can select every city area within that state thats covered by CL.
It would be easier if u could select a state or nationwide with one click. But you can do the same thing by selecting cities. Will take a while.
Also you cant seem to select the same saved search in different cities. But you can select by distance in filters.
CL is antiquated and the founders sold it to Ebay so maybe Ebay doesn't care to dump any $$ to properly update and provide oversight the software and app.
Oh, gotcha. I had multiple cities added, but even with the distance filter set to 2000 miles it was only pulling up local stuff. Turning it off seemed to do the trick
