cant seem to get the control arms to accept the grease, any tips? it looks gross in there and would like to get them fresh again
Do they have greaseable bolts or are they greased through the body.? Greaseable bodies do not work well in the first place and it is usually better to tear them down and clean, grease and reinstall them .cant seem to get the control arms to accept the grease, any tips? it looks gross in there and would like to get them fresh again
Not all the current offerings include the greaseable bolt. That is the best way to grease them but do not try to force grease into them. Most of the time you will be lucky to get one pump into them and no more. They take a lot less grease than you might think.they're johnny joints so they have bolt grease ports as well as around the joint body. removing them seems like a PIA and would rather avoid that
That's it in a nutshell... There's practically no place for it to go.The bottom line on Currie's Johnny Joints is their internal tolerances are tight enough that they won't readily accept grease until they're really worn. Mine are 11-12 years old and they're still not so worn that they readily accept grease. As above, if they're not groaning when you're on the trail they're fine.
