Wildman's TJ is getting a face lift
Paint turned out good IMO.
Need to order more so I can paint the axles now.
Second coat on and tomorrow I'll sand down all the runs and touch up anything I need to before I flip everything and paint the back sides of all the parts. WHAT A PITA....
Front fenders
Rear corner armor and tie in piece for the lower area.
Not too bad for my first time EVER trying to paint with a paint gun.
What all are you doing to it? Looking great so far!
That is a LONG answer. You'd have to go back and read the whole thread.
The short?
Rebuilt engine & installed stroker crank making the Dodge 360 a 408 or 5.9 a 6.7
Installing built 46RE transmission
Stretched frame 4.5" and moved rear axle back 5"
Steering box rotation kit & stretched front forward 2.5"
Painting frame Hot Rod Black
Painting body armor color match White
Painting flare Black
Built new wiring harness for V-8 swap
Still need to rebuild the Warn 8274 winch and then paint it prior to reassembly
And a ton of little stuff along the way like having to regear my rear axle because I had broken pinion teeth.
The short?
Wow. That's a serious build. I've got a old Toyota that I'm building to that level. It's fun but very involved
The short?
Yep. Easy peasy😁
Reactions: Alex01
Man you do good work. I may have to drive up there for some pointers lol. I cant paint to save my live. I can turbocharge a lawnmower but I can't make it look good lol
Believe me this is my first attempt at painting with a paint gun. So I'm learning as I go.
And a hair got onto the one corner armor... DAMN IT. And then instead of waiting I tried to get it out which made it worse.
So wait for it to dry a bit more and sand it down and then respray it.
  • Sad
Reactions: reddvltj
Well don't stress it, everything else looks great so far. You have to keep me posted with your progress.
Reactions: Wildman
Reactions: Wildman
Looks like you’ll be painting the rest of the rig then. Looking good.
Bite your tongue. I DO NOT want to try painting the whole rig. That is not in my plans.
But MAN does the clear make the paint POP.... Heck I'm impressed with myself and that takes a lot... It's hard to capture in pictures but this paint looks great.
Told you you'd be happier learning to paint then using cans.
It looks great!!!! Can't wait to see them back on the jeep!
