You haven't been around here long enough to have been witness to the whole Steel vs Aluminum debate and how some feel saving 200lbs or 300 lbs is VERY important...
I have steel armor so I'm WRONG and am OLD school. Last time I weighed my TJ before this whole rebuild it was just over 5K lbs with me in it.
Add this to your jeep and all will be forgiven. https://savvyoffroad.com/product/sav-vlnc/
Actually just to piss off those whom we don't speak of I was gunna get this one.
https://metalcloak.com/tj-lj-wrangler-tail-gate-finish-plate-aluminum.html
Would you build it with aluminum if you could’ve done it all over again?
WOW, almost seems a shame to ceramic coat this exhaust. That stainless steel sure pops.
But I'll take the heat reduction.
Fantastic progress!
I have said it before, and I’m sure I will again, making the y-pipe for my TJ Hemi conversion was by far the hardest part of the entire build. And I started with a bare frame and did every single thing to make it whole again…
Dam that thing is heavy. 2 np231s
Soo short for a 2 speed though...
3 speed not 2....
I have 3.05 & 5.44 low ranges to choose from.
While not quite as deep as a Atlas 4 it's enough to know you're in low low.
@NashvilleTJ what does the Atlas 4 weigh? And overall length?
I thinks it’s something like 120 or 130 pounds. I don’t remember the exact length, but I remember it being shorter than a stock 231.
3 speed not 2....
That is totally what I meant, damnit
What sucks now is that if mine takes a dump I'm SOL.
Good thing you aren’t sending LS power through it.![]()
Forgot to add that after talking to them I did go with Glacier Black for the headers. And then Gray for the Y pipe and cat. Both coatings are rated for 1,000⁰ and have better thermal properties. So less heat being radiated from the exhaust.
So should help with the under hood temperature and under the tub too.
In retrospect - I wish I had coated my entire exhaust, instead of just the headers. Those cats and twin tubes under the passenger floor throw off a lot of heat.
