Paint it. What's the clamp attaching to? Aluminum or DOM tie rod?
I'd suggest welding some small "bungs" to the tie rod, on both sides of the clamp. Then the clamp won't move.
I don't have any way to weld to aluminum right now. As I said before I never had any issues with my old clamp sliding but since it's been brought up I'm trying to do all I can to prevent it. The TMR clamp has biters that screw into the tie rod on the bottom. This clamp was actually made for a steering stabilizer so was threaded for 1/2" bolt in the center. I'll install one set screw in that spot.
I'll paint the inside area.
Bedline it
Now I think that might be going to extreme...
It won’t slide easier. The friction difference is negligible.
I'll have to agree with @FarFire70 about the packaging from Bolt Depot.
Got the fittings I need for the master cylinder from Speedway Motors.
Won't have everything to finish the hydo-assist ram until next Tuesday.
Glad you had a positive experience off the recommendation. I've been impressed - have more nylocs on the way for my build. Their by-hardware vs by-bag is a benefit.
Wait until you order 20+ separate items. Those bags are a life-saver keeping things straight.
How was shipping time from order to delivery for you?
I don't think I've ever had a underhood light on my TJ since I've owned it... Or if I did maybe it just didn't work? So I'd picked up a LED version but or course the plug wasn't correct. The same plug that worked on the alternator module fits the underhood light. The ONE thing I don't like is that it needs some sort of a On/Off switch for those times when the hood is opened for an extended amount of time. I've still got to try closing the hood to make sure it turns off.
And the plug. I've still got to splice it into the harness.
Mine never worked right. The weighted switch was temperamental so I usually had to tap it to get it to turn on....
Been thinking to install an LED bulb like you did. I also saw someone who ran a strip of flush LEDs on tape up the hood to get increased coverage.
Yours looks to provide some pretty good coverage. Shadows are always the enemy with the under hood bulb. Which is where the LED strip drew my attention.
I picked up one of the GM reel style lights to put under the hood, but I haven't got around to installing yet.
Like this one but mine came with a LED bulb.
https://www.ebay.com/itm/2566827726...pid=5337789113&customid=&toolid=10001&mkevt=1
