I wanted to reply to this thread even though it is rather old. I searched and searched for info on how to do this swap and was not able to get any answers. So here is my solution to deal with installing a 1993 YJ 32rh into a 1997 TJ. I am not big on long writeups so ill keep it simple.
1. The transmission will bolt up.
2. You will need to use a 1993 torque converter. The 1993 32rh trans has a different input shaft and the 1997 TC did not fit.
3. The 1993 torque converter has a different bolt pattern. Three holes will bolt up to the 1997 flex plate but the fourth is about a quarter of an inch off. You will have to elongate the hole to fit the 1993 TC.
4. The torque converter lockup solenoid is a single wire solenoid in the 1993 YJ transmission. The solenoid will lock up when it sees 12v from ecu. The 1997 uses a two wire where the solenoid gets constant 12v from accessory and locks up when it sees ground. You will have to wire up a relay to send 12v to the 1993 solenoid in your trans when the 1997+ ecu closes ground. See the diagram below.
5. You will need to buy a spare 1997 solenoid to use as a dummy and just sit outside the transmission so that the ECU does not throw a check engine light. I guess it goes through a check to see if the solenoid is there and if it does not see it it will throw a code. I just mounted one with the relay. I am sure you can measure the resistance of the 1997 solenoid and then figure out how to trick the ecu with some kind of a resistor, but the dummy approach was easier for me to do. If someone smarter than me figures out the resistor route please let me know. Again, see the diagram.
Good luck.
What about the sensor in the bell housing.
